It is currently Sat Feb 24, 2018 1:02 am
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Scrum Front Row Mismatch
Mini Player
Post Scrum Front Row Mismatch
Very Often our Front row is heavily mismatched and we are not sure how to get the best out of our arrangement.
Our front row consists of 3 players who are 5 ft 7" 18 stone , 5 ft 5 16 stone, 5 ft 7 18 stone.
We are all quite flexible and as a result we can almost get 1 ft lower than our counterparts who tend to be about 20 stone 6 footers.
More often than not they wont come down to our level and the referee forces our side up thus giving away our advantage.
Is there anything anyone can recommend ??
Wed Jan 08, 2014 3:54 pm
Post Re: Scrum Front Row Mismatch
Free beer for the ref for a month?
Wed Jan 08, 2014 3:56 pm
What is happening after the engage, you bettering the opposition are having problems. What age group are you, senior ? Youth ?
"Business!' cried the Ghost, wringing its hands again. "Mankind was my business; charity, mercy, forbearance, and benevolence, were, all, my business. The deals of my trade were but a drop of water in the comprehensive ocean of my business!”
“None are so hopelessly enslaved as those who falsely believe they are free.”
"The price of anything is the amount of life you exchange for
Wed Jan 08, 2014 4:03 pm
Mini Player
Senior players, Most engages goto ground because we are much lower than the opposition. Eventually the referee gets sick of it and brings us up higher but why should we give away our advantage it makes no sense the way the refs treat us ?
With the new laws we are dominating when a scrum is low and stays up
We prefer to be a mobile small pack rather than the big heffers you see in our league.
Is there any law regards scummaging which implies both teams need to engage at an equal height and whos responsibility that is ?
Wed Jan 08, 2014 4:52 pm
Although you are smaller you shouldnt be fixate on keeping low IMO, come up on the engage the ref will want to see you driving from a low position upwards, this is fine, you can drive up but from underneath your opponent. Particularly if you are loosehead come up and slightly across into the sternum of the tight head. Your aim is to drive forward and up to disrupt the TH by getting the back of your head under his sternum not under his armpit, use the muscles in your neck to push the back of your head into his chest. So try to engage under his chest and keep him up if your short. The further down you drive the further you have to come back up, needing a stronger bind and more strength and will result in more collapsed scrums. If the TH can pin you down he is happy.
TH also engage low and stop the LH getting under you then drive towards the 8 to split the hooker from the LH and get the LH under your outer arm instead of your chest.
Your height advantage should be to get under the opposition and raise them so the force is dissipated.
Just my opinion :)
Wed Jan 08, 2014 6:37 pm
Mini Player
SCRUMS SIMPLIFIED
There has been no effectual changes to the scrum downs. The idea that the hooker needs to be jammed farther forwardto reach the ball was created initially over 120 years ago. At that time there were as many as 5 or 6 per side in front row.The only purpose this serves present day is to create an unnecessary pressure point. From that center point the front row can be pushed, pulled and twisted left, right, up or down. The clear alternative to this is in fact already in the law book under front row binding. Have the hooker come in under the props in support of front row; and not to a convex point:
But rather slightly concave. In other words the hooker will not throw his arms over and around the props as
they set up for scrum but the opposite. The props wrap over and around the hooker. There are several other advantages to this: For example the hooker is has more freedom not just to protect himself but also easier to engage his rearbumpers / locks or not his preference. This improved method not only lessens the wheel and/or collapse but relieves much pressure off tight head and hooker. I played for 34 years - 31 as a hooker. Don't be so quick to condemn or ridicule before trying it. I've done it-It Works just fine.
Sincerely,
Thu Dec 18, 2014 2:49 pm
^therin lies the key. Get under 'em and hoist 'em high.
Thu Dec 18, 2014 10:23 pm
I've seen more than one referee penalise a front row for pushing upwards in the last couple of years.
When that happens, you need to have a soothing beer.
:angry4:
Fri Dec 19, 2014 7:00 am
Site Admin
:angry4:
If you get your head under his chest and drive forward (and up) then it appears OK to the ref. THAt is the trick :)
OSPREYS REGIONAL RUGBY - The One true region - SOUTH West is best Boys Butti Innit
Internet Marketing Consultancy - SEO Agony Uncle
Fri Jan 16, 2015 12:26 pm
:angry4:
Too complicated for me, Chris.
Fri Jan 16, 2015 4:00 pm
:angry4:
You must have thought about that one for a while !!!! 13 months :shock:
How did that thread pop back up :D
Fri Jan 16, 2015 5:08 pm
:angry4:
Only 1 month old fella. :D
Religion is like a penis.
It's fine to have one, and fine to be proud of it.
But please don't whip it out in public and start waving it around,
And PLEASE don't try to shove it down my child's throat.
Thu Jan 22, 2015 5:19 am
Just pretend you're a plain taking off!
Simples init
Just don't make the engine noises, you might get a funny look :D
Tue Mar 31, 2015 3:02 pm
Any consideration and empathy I might have sails right over the head of men 5'7" or shorter.
Burpity burp burp
Tue Mar 31, 2015 7:11 pm
Tue Mar 31, 2015 7:38 pm
Users browsing this forum: No registered users and 2 guests
