It is currently Fri Feb 23, 2018 9:35 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
*** If you are blocked from visiting this site at work ***
Post Re: *** If you are blocked from visiting this site at work ***
lloydsa wrote:
If you are blocked at using this site at work.
Get back to bloody work you should be working what do your company pay you for Geeeez
I would but the compilations and build take so long I get bored ... battlin' witts here keeps the mind active .. it's good for the business lol!
.. besides when its all gone snafu and you haven't a clue .. :kermit: where else do you go for inspiration?
Sun Mar 25, 2012 11:31 am
1. Go here
http://www.ip-adress.com/proxy_list/
Take one of those proxies test it and copy the ip and port
2. Then go here
http://www.hack.net.br/webpac/
At the bottom block enter that IP and port no
Press generate.
Copy and paste that bit it generated to a new txt file but rename it proxy.pac. Save it somewhere on your pc
At use automatic proxy config in your browsers setting add the location of that file eg C:\Proxy.pac
Now your set. Everytime you want to change the proxy just edit the file with a txt editor and replace the ip and port in it with a new one and save it again
Easy yes? :cheers:
Sun Apr 01, 2012 2:06 pm
Club Player
Agreed it's just another example how the country is going down the pan.
The old Protestant ethic well and truly buried.
Thu Aug 13, 2015 5:11 pm
Users browsing this forum: No registered users and 4 guests
