It is currently Sat May 26, 2018 11:08 am
Post new topic Reply to topic  [ 9 posts ]
.JPE
Post .JPE
for some reason when I try an save an image it shows as .JPEG but once its saved its turns into .JPE and photobucket doesn't want to know
Any ideas whats happening?
Sat Oct 03, 2015 6:33 pm
Post Re: .JPE
What vehicule(s) are you using to save?
ImageEasy to consider past and present, it's the future and associated plan and strategy to achieve that takes the talent ..
Sat Oct 03, 2015 7:32 pm
Post Re: .JPE
PS try and just rename it with a g ;)
Sat Oct 03, 2015 7:51 pm
Post Re: .JPE
Change the bot to search all files and see if it opens, then re save it as what you want
Sat Oct 03, 2015 7:55 pm
Post Re: .JPE
How'd you get on Fids?
Wed Oct 21, 2015 6:54 pm
Post Re: .JPE
so eloquently put but saying .. 'change the bit after the dot to jpg' might elucidate your point?
right click the file and select rename etc.
but of course etc won't work either duhhh!
:kermit:
Sun Dec 13, 2015 7:07 pm
Post Re: .JPE
Sounds like, you need to adjust something in your camera settings?? This is what it says according to PC Mag online?
.JPE file
An optional extension used for JPEG files. Some Sony cameras have an option for simultaneously recording a low-res file for e-mail attachments that is saved as a .JPE along with the high-res .JPG file. Some Minolta cameras use the .JPE extension for images that contain embedded color profiles, and .JPG for ones that do not. Most image editors treat .JPE files as ordinary JPEGs, while other applications do not recognize the file type at all.
Maybe you have a default setting to save as .jpe in the image-settings? My Camera funny enough, gives me 2 file-types, when I change settings from .raw to .raw_only? (It saves both, the Larger sized file is .raw and the other is .jpe) I just changed my settings to 'Raw_only' instead of just 'Raw' in the image-format settings? Weird thing all the same, it doesn't happen if I choose to save as .jpg or 'raw_only'!!
"I have to say, I find that offensive toward (insert cause/belief)"
Bit of tough luck for you then, old chap. I really don't give a toss about your perceived sensibilities!!
Thu Apr 07, 2016 1:17 am
Post Re: .JPE
camera images are fine its copied ones that go tits up but I think I've found a work around
Have to save them twice and as Tel said, add a G on the second :D
Thu Apr 07, 2016 6:36 pm
Post Re: .JPE
Does this help http://www.batchconverter.com/ I'm sure you could get a "free" copy from somewhere
I'm politically correct, a social justice warrior, a Snowflake and a male feminist ......apparently
I'm also a dopey *bar steward* a childish fukkwit and a liar
Thu Apr 07, 2016 10:04 pm
Users browsing this forum: No registered users and 5 guests
